BTS Posted November 29, 2010 Share Posted November 29, 2010 Hey Im just about to do the First Service to my R50 5 spd. I just crossed 270xxx.. I'm gonna go to the dealer tomorrow to see if I have LSD in the pfinder. Just wondering about fluids : Amounts and Type and if I need an additive; 1. Front Diff 2. Transfer Case 3. Transmission 4. Rear Diff I already did a main check over of Brakes and Brake Fluid, Engine Oil, Coolant. Everything checked out good. Also is there anything that I should also check anything else??? Link to comment Share on other sites More sharing options...
SilverPath Posted November 29, 2010 Share Posted November 29, 2010 (edited) I don't know if they charge you for that check, but you can do it real easy yourself if you want, Crawl under your rig and see if you can see an orange sticker on the rear diff. If there is one you have an LSD. You can also take a jack and lift the rear of your Pathy by the rear diff so both wheels are off the ground. Now spin one wheel and if the other spins in the same direction you have an LSD if the other direction then its open. For Fluids here a is a good write up with procedures w/#'s that lee_cha_nin did. http://www.nissanpathfinders.net/forum/index.php?showtopic=23891 I think there are other threads on them also Edited November 29, 2010 by SilverPath Link to comment Share on other sites More sharing options...
