Der_Vier Posted September 26, 2010 Share Posted September 26, 2010 Before I get for asking, I did try a few searches and didn't find much of what I was looking for, if this topic has been discussed though please do point me in the right direction...anyhoo: How do I go about checking the manual tranny fluid on my 98 r50? I am assuming that I have to undo the plug and stick my finger in. Where abouts is the plug located and will I have to buy a special tool to undo the plug? WIll I need to somehow jack the truck up? (at college, no jacks with me) Again if this has been covered sorry for posting this Thanks in advance IV Link to comment Share on other sites More sharing options...
vmodi Posted September 26, 2010 Share Posted September 26, 2010 Its going to be hard to check the fluid especially without jacking up the truck. The hole is located at the center and to undo it you will at least need a breaker bar. I had the same problem but I decided to just go ahead and get the fluid changed, ended up using GL4 Royal Purple. It was never changed in my truck before I bought it, if its the same for you then better get it changed, it became fairly smooth after the change. Link to comment Share on other sites More sharing options...
MY1PATH Posted September 26, 2010 Share Posted September 26, 2010 (edited) search "manual transmission" 2nd page of results TSB check out that whole thread. Edited September 26, 2010 by MY1PATH Link to comment Share on other sites More sharing options...
Der_Vier Posted September 26, 2010 Author Share Posted September 26, 2010 @ Vmodi: How much did the change cost you? @My1path: Thanks, I lurked it, but I cannot tell if that TSB covers my transmission also? It says up unitl 95. Did they use the same transmission in the R50? Link to comment Share on other sites More sharing options...
rgallant Posted September 26, 2010 Share Posted September 26, 2010 Hi there I had both diffs, the transfer case, transmission, full steering inspection and all the front swaybar bits done (I bought the parts for that) 250.00. Make sure they check the transmission oil for gear teeth bits, found a couple of reverse idler bits in mine. As it was new to me and I have a mechanic I trust it was worth the money for piece of mind, besides now I can spend money on toys. Link to comment Share on other sites More sharing options...
Der_Vier Posted September 26, 2010 Author Share Posted September 26, 2010 Not too shabby, I will look into having that done Link to comment Share on other sites More sharing options...
