Engine parts, pathy vs 300zx
Guest Pathy4X4
Guest Pathy4X4
Hey I have an older 300zx sittin around here. Will parts be compatible with my pathy engine?
Like heads or crankshaft and anything else, and will they increase HP?
I know they are both the VG30E engine but are the parts on the Z more performance?
thanks for any input
#1, it's basically the exact same engine, and the Pathy upper intake actually makes more power than the 300Z intake does. Moot point. If you swap all that stuff out, it'd basically be rebuilt and would make more power, but I wouldn't expect much without upgraded parts.
#2, no. Another snake oil type gizmo that won't do anything but make your engine run richer and possibly advance the timing a little. I dare someone to post an actual dyno run back to back with that Venom thing. I bet there's no difference, much less a difference you can feel.
Guest Pathy4X4
okay thanks for the info.
I thought that was the case on that venom thing, just thought I would get a second opinion.
