blackpirate555 Posted August 22, 2010 Share Posted August 22, 2010 Hey all just signed up, I have a 95 nissan pathey 3. slow. Anyway I love this truck. I have recently done a complete engine swap. The donar engines from a 95 atomatic and i sucessfuly completed the swap. into my 95 manual. the engine runs great. heres the trickey part, since i had the truck in pieces i thought it was wise to throw a new clutch in. It was ok at first but started slipping when the truck warmed up. After playing around with the clutch petal distance it seemed to help a little but not alot. so i changed the cluch master cylinder and slave. Then i noticed theres no more resistance on my thrust bearing arm, I think that the springs come loose. my question is is it possible to get it back on without dropping my trannie, I know its a shot in the dark, and its such a simple mechaninism for me to go through all the work dropping my trannie to fix. Link to comment Share on other sites More sharing options...
ahardb0dy Posted August 22, 2010 Share Posted August 22, 2010 Sorry can't help with your question, but someone on here will be able to I'm sure. But WELCOME TO THE SITE !! And as we all ask of new members WE NEED TO SEE PICS !!!, LOL Link to comment Share on other sites More sharing options...
Precise1 Posted August 22, 2010 Share Posted August 22, 2010 Howdy and welcome!! So you are saying that there is no resistance to the actuating arm that the slave cylinder moves?? It can be moved over it's range of travel?? It's been a while but IIRC there was a clip that held the throw out bearing carrier in relation to the fork, it sounds like this slipped, is broken, etc?? I seriously doubt that there is anything you can do from outside of the bell housing and for peace of mind, I wouldn't recommend it anyway. You should pull the tranny back so you can look inside. The good news is that you don't have to take everything apart to do this, you can just drop the rear cross member (the ones the T bars tie into) and slide the tranny back, that'll save some work. Good luck and let us know what happened!! B Link to comment Share on other sites More sharing options...
blackpirate555 Posted August 22, 2010 Author Share Posted August 22, 2010 Howdy and welcome!! So you are saying that there is no resistance to the actuating arm that the slave cylinder moves?? It can be moved over it's range of travel?? It's been a while but IIRC there was a clip that held the throw out bearing carrier in relation to the fork, it sounds like this slipped, is broken, etc?? I seriously doubt that there is anything you can do from outside of the bell housing and for peace of mind, I wouldn't recommend it anyway. You should pull the tranny back so you can look inside. The good news is that you don't have to take everything apart to do this, you can just drop the rear cross member (the ones the T bars tie into) and slide the tranny back, that'll save some work. Good luck and let us know what happened!! B Link to comment Share on other sites More sharing options...
blackpirate555 Posted August 22, 2010 Author Share Posted August 22, 2010 yeah there was a spring clip that held that thing on where the bearing attaches on too, thanks for the advise im positive now that is the case. my truck is soo close to being done. ill try and get some pics up soon as i can. Link to comment Share on other sites More sharing options...
blackpirate555 Posted August 22, 2010 Author Share Posted August 22, 2010 what you say makes a lot of sense. ill give it a try... by a look at all these threads it would be smart to get a transmission jack if i do have to drop it to put that spring thing back on my thrust bearing Link to comment Share on other sites More sharing options...
Precise1 Posted August 22, 2010 Share Posted August 22, 2010 It was 5 years ago that I did my Pathy clutch, but I think that is what I remember. Regardless, you are going to have to look inside. Yes to the tranny jack, I can't imagine any other way of doing it, at least solo... B Link to comment Share on other sites More sharing options...
Kingman Posted August 23, 2010 Share Posted August 23, 2010 (edited) Sounds like the clip came off inside. Like B said, just remove the rear cross member, drive line, wiring to the transfer case, transfer case selector and mechanism, and slide the transmission back and take a peak. One other thing, you did remove the flex plate locating spacer on the back of the crank and installed a pilot bushing, right? Edited August 23, 2010 by Kingman Link to comment Share on other sites More sharing options...
teixeira Posted August 23, 2010 Share Posted August 23, 2010 Sorry can't help you, but sure want to see pics... Link to comment Share on other sites More sharing options...
