Indigent Posted May 29, 2010 Share Posted May 29, 2010 Lately I have been considering rebuilding the spare set of fuel injectors I have laying around. I have contacted 3 different injector shops and all of them say that the filter baskets on these side-feed injectors are not replaceable. In a way I refuse to believe that, but whatever. I am not content just replacing the o-rings on these injectors. I can see crud inside the screens. My next option to consider is swapping the whole fuel rail to a style that has a rebuild kit available. I have the ability to modify the injector pulsewidth in the ECU ROM, so theoretically, I can make any injector work. Fitment is the only issue. Is there anyone out there in pathfinder land that has looked into other-than-stock injectors? The 300zx crowd has a bunch more room to work with than we do. Link to comment Share on other sites More sharing options...
beastpath Posted May 29, 2010 Share Posted May 29, 2010 you could use the 3.3 injectors. they will fit into the rail, but you would have to splice the connectors into the harness as they use a clip style. Link to comment Share on other sites More sharing options...
Indigent Posted May 30, 2010 Author Share Posted May 30, 2010 the 3.3 injectors are the same style as the 3.0 Link to comment Share on other sites More sharing options...
beastpath Posted May 30, 2010 Share Posted May 30, 2010 the 3.3 injectors are the same style as the 3.0 i thought they were slightly higher flow rates Link to comment Share on other sites More sharing options...
