Replacing Clutch
I don't know if there is a write up per se, but it has been discussed often. I did mine with a Haynes manual just fine but go to the Garage section and down load the FSM pinned at the top for a 1994, it will work fine for you.
The job is pretty straight forward, just a lot of work.
I'll try to find some of the threads later when I get home if I remember...
