Changing Transmission And Differential Fluid
vmodi
Two topics:
1. Changing manual transmission fluid
Got the Max Gear 75W-90 GL4 fluid and found the drain plug on the transmission.
However, it doesn't seem like the fill plug is easily accessible. What do you guys use? I was thinking of buying a drill pump, two sets of pipes and trying that route. All I have to lift the car are Rhino ramps.
Thoughts?
2. Changing the front differential fluid
Again, found the drain plug but the fill plug doesn't seem to be easily accessible. Same problem as above.
you can get a simple hand pump made for this problem at your local auto parts store, I got one at Oreilly's for $8, it's actually made to screw on the top of the gear oil bottle
Fill the tranny from the shifter hole,not the factory filler hole...
Where is the shifter hole? Do you have any pictures?
