How to dim an LED light on a switch
Cubby
I have an illuminated rocker switch I use for a pair of driving lights (Radio Shack PN 275-731). The red LED light on it is too bright. How can I dim the light on it. I am not an electronics guy but I assume I can install some type of resistor on the negative connection? I do have a non-illuminated switch I could use but I light having an indicator on the dash that the lights are on.
Thanks in advance.
An LED is going to be harder to dim. Unfortuatelly an LED doesn't have as wide a range of brightness as a light. I tried it just for $h!ts and giggles with a 1 kohm (1000 ohm) resistor. It dims a bit. Might be enough to help you. Just install it in series and try it. Just so we're clear to connect the resistor in series, disconect the wire going to your light on your switch, solder one side of the resistor to your switch prong and the other side to your wire or connector you just dissconnected. Hope this helps and good luck!
