One Quick Atfquestion
bsb1957
I was just wondering what eveyone is running as far as ATF.I have A 92 3.0 Auto.It seems the more i search the net the more i wonder what would be best.I realize what the manual calls for but was wondering with the advances made in the last 18 years maybe there is something better out there?Thanks
I've been advised by a Nissan/Infinity mechanic that Dextron3/Mercon is perfectly adequate. It thermal properties are not quite as good as the Nissan D or S fluid (recently changed) but as long as you check it occasionally/change it per recommended interval, it should be a non issue.
