kcpath Posted March 18, 2010 Share Posted March 18, 2010 I rebuilt my engine 92 pathy v6. I cranked it up a few times this morning but didn't drive it until I got my header cross pipe on... Then when I finally got it on I checked all the fluids again and this was my first road test. It fired right up. Drove it around for about 5-7 miles and noticed when I would sit for a few seconds the water temp would go up a little bit so I turned around and headed for the garage. I kept it running while I popped the hood and noticed there was a small leak in a hose...(I didn't put the fan or shroud on during the first road test.) So I checked the temp gauge again and it was getting a little hot. I shut it off to let it cool for several minutes. Went I went to crank it would not start. Fuel pressure is good, spark is good, injector pulse is good...checked the fusible links. NOW WHAT?!?! Link to comment Share on other sites More sharing options...
olddirtyrake Posted March 19, 2010 Share Posted March 19, 2010 I rebuilt my engine 92 pathy v6. I cranked it up a few times this morning but didn't drive it until I got my header cross pipe on... Then when I finally got it on I checked all the fluids again and this was my first road test. It fired right up. Drove it around for about 5-7 miles and noticed when I would sit for a few seconds the water temp would go up a little bit so I turned around and headed for the garage. I kept it running while I popped the hood and noticed there was a small leak in a hose...(I didn't put the fan or shroud on during the first road test.) So I checked the temp gauge again and it was getting a little hot. I shut it off to let it cool for several minutes. Went I went to crank it would not start. Fuel pressure is good, spark is good, injector pulse is good...checked the fusible links. NOW WHAT?!?! Bad starter? Link to comment Share on other sites More sharing options...
