ChrisPerna Posted February 8, 2010 Share Posted February 8, 2010 so the other day my headlight exploded in my housing. so i took the housing out and took out the glass and replaced the bulb. so now when i replaced the bulb the fuse was burnt out. so i replaced the fuse and it will work for a little while and then burn out when i switch my high-beams. only sometimes though. Any ideas thank you Christopher Perna Link to comment Share on other sites More sharing options...
Kingman Posted February 8, 2010 Share Posted February 8, 2010 When fuses blow the first thing to check is the grounds. I would check and double check those to make sure they are good as well as the rest of the wiring that you can get to. If that's all good then there may be a bad contact in the headlight stalk; all the headlight power is routed through that. Link to comment Share on other sites More sharing options...
edicer2 Posted February 8, 2010 Share Posted February 8, 2010 yeah the connections on the part that clips onto the bulb sometimes those get crusty after time and dont connect good Link to comment Share on other sites More sharing options...
ChrisPerna Posted February 9, 2010 Author Share Posted February 9, 2010 ok so what happened was that i took out my switch for my foglights when i replaced my carpet and the wires kept hitting and shorting out the fuse. Link to comment Share on other sites More sharing options...
