AC coil installation
i know the rear is fairly easy for the AC lift, i am just unsure of which way the springs go, and which way they're supposed to face. there are no markings on the springs. we did the front already, but now the back needs to be done! my car is undrivable until then! any information would be greatly appreciated. Thanks!
-Rob
If I remember correctly there is no difference, if anything one end of the springs will be flattened out and that side goes on the bottom. But other than that, jack up the rear of the pathy, then undo one of the shocks and let that side of the axle droop down, the coil should just fall out. After that, install the spacer if you're using one, compress the new spring jack the axle back up and bolt on the shock again, or a new shock.
