Overdrive Not Working?
AeroSync
Perhaps it is possible that the switch has shorted and you are always in power mode but the bulb is burnt out?
Or some combination of the two?? Yes, that could have somethiong to do with it. Time to pull the switch and examine it, the cntacts and the bulb.
You won't get all the fluid out, only something like 1/2 but the exact amount is uncertain. The best way is to measure what came out and put that much back in, or at least close and then go by dipstick. I'll check my manual in a bit...
Thanks Precise1.
Onto the OverDrive, I was going 40 - 50MPH and I pressed the over drive button (light up on dash) and there was no apparent change in my gears. So it could be an electrical problem like mentioned.
