Rear Seat Conversion
wilson
sorry for the double post but I have been searchin for a couple days now. can anyone point me in the direction of the rear seat mod that allows you to take out the rear seats to allow for more room for gear/sleeping?
thanks alot
wilson
un-bolt the 2 hinges @ the bottom of each seat.
get a drill 1/4" IIRC
drill off the expanded end of the hinge pin
use a hammer and punch to knock the pin all the way out
get a bolt & wingnut or use a lynch pin to replace the hinge pin
re-install hinges and use wingnuts or lynch pins every time you want to remove the seat bottom.
here's what the aproprieate lynch pin should look like. I got mine @ lowes for about 4 bucks each
