mudfinder Posted September 7, 2004 Share Posted September 7, 2004 hey guys, i have one question, if i wanted to make my pathy 4wd, would i need a new transmission or would the transfer case go on to the one i already have on? and is it possible to make it 4wd if i went and picked some parts off another path at a junk yard? Link to comment Share on other sites More sharing options...
Cuong Nguyen Posted September 7, 2004 Share Posted September 7, 2004 You will need a new transmission and transfer case. You can't swap the tailhousings. It's not possible. If you're lucky, you can find a good parts pathy that someone wants to get rid of and pull everything from it. The whole swapping is ALMOST bolt-on except you have to WELD the front crossmember where the front diff mounts to. There are no pathfinders in my area that I can get so that is out of the question. I tried looking up the parts individually and found out that I'd end up buying another Pathfinder. So.......... I'm back to my solid axle swap as originally planned.. Link to comment Share on other sites More sharing options...
mudfinder Posted September 9, 2004 Author Share Posted September 9, 2004 when i get the money, i want to put a solid axel in the front, why not get a 4x4 instead and will be much cheaper? because my pathy is my pathy. and when i have kids i'll tell them that this thing was once 2wd and it kicked hiney. and plus i have too many memories, don't want to get rid of it. Link to comment Share on other sites More sharing options...
Cuong Nguyen Posted September 9, 2004 Share Posted September 9, 2004 yeah i know what you mean. my pathy has sentimental value. I'd would hate to see her go. from what I meant earlier, totalling up the parts to complete the conversion, the price is about the same as 4x4 Pathfinder up and running. Link to comment Share on other sites More sharing options...
mudfinder Posted September 30, 2004 Author Share Posted September 30, 2004 i was looking at some salvage trucks at copart. i was thinking what if i get a rolled over or totalled Pathfinder, i'd perfer rolled because the drive-traine won't be damaged. rip the front end off the totalled one and put it on my path. i could get one for probably 3-400 dollars. what you guys thinks? Link to comment Share on other sites More sharing options...
sw Posted October 1, 2004 Share Posted October 1, 2004 if the price is right then go for it, you wount look back for a second as long as the entire driveline is there and not damaged & arms and hubs etc it would be pretty cool if one of you guys did it Link to comment Share on other sites More sharing options...
87pathy Posted October 1, 2004 Share Posted October 1, 2004 I wouldn't say You have to have a new tranny and T case. You might be able to use a 720 divorced transfer case. Link to comment Share on other sites More sharing options...
mudfinder Posted October 2, 2004 Author Share Posted October 2, 2004 see, i work with alot salvage vehicles, the only reason why i said a rolled over one is because the ones rolled over don't usually have drivetrain damage. and i am going to do it. i'm just waiting to buy my titan so that i'll have something to drive daily, i know it's not going to take a weekend or a week, it's going to take a while. so that's my plan, there's no way i'm buying a 4x4 Pathfinder in the place of my mudfinder. it's my baby. so we'll see, i might even go ahead a do a SAS. Link to comment Share on other sites More sharing options...
