timmeh77 Posted September 8, 2009 Share Posted September 8, 2009 Can someone walk me through the removal/installation of lower front ball joints on a 92 pathfinder. I have got them separated and have disconnected everything a chiltons guide tells me to but i cannot get them out. There does not seem to be enough space between the knuckle and the cv joint to remove them. What needs to be disconnected to create that space? Thanks Link to comment Share on other sites More sharing options...
adamzan Posted September 8, 2009 Share Posted September 8, 2009 You need to remove the hub and snap ring, and push the cv out to make room. That is what I had to do. Link to comment Share on other sites More sharing options...
timmeh77 Posted September 8, 2009 Author Share Posted September 8, 2009 Thanks, that is what i was thinking but hoping i did not need to do. so you remove the hub and snap ring then are able to slide the cv out an inch or two and create the space? Anything I should know about removing a hub, i am pretty ignorant about what is in there and what is important. -Tim Link to comment Share on other sites More sharing options...
Cyril Posted September 8, 2009 Share Posted September 8, 2009 Had no probs when doing mine , just lifted the upper control arm up with all connected ( minus the lower joint connected ). Just a thought , you don't have a jack or axle stand under the lower control arm which is stopping it reaching it's full movement ? ( could even remove the upper control arm rubber which gives another 1'' of room ) . Link to comment Share on other sites More sharing options...
