FrostTheOne Posted July 29, 2009 Share Posted July 29, 2009 Just wondering if anyone has use this product. It seems like a good package when I priced out the parts individually. Just wondering, cause if I'm gonna do ball joints and have it all apart, maybe I should do it all at once. http://ruggedrocksoffroad.com/calmini-hd-u...-95-p-3682.html Link to comment Share on other sites More sharing options...
OldSlowReliable Posted July 29, 2009 Share Posted July 29, 2009 (edited) they squeek. Other than that, I don't think there are alot of complaints with em, but if you run a bigger shock with them, they WILL damage the shock. You can get those minus the ball joints for under 250 if you order a d21 pickup lift kit from rough country through a private distributor, and that comes with 4 new shocks Edited July 29, 2009 by OldSlowReliable Link to comment Share on other sites More sharing options...
92Pathmaker Posted July 29, 2009 Share Posted July 29, 2009 (edited) I like mine. I just put some Skyjaker nitro shocks on and had to cut them some. I just made the fat side the same as the other. The shock has clearance the full range now. They even dented the Calmini shock that came with them. I have heard that the new ones don't squeak any more. I just use a marine lube on mine once a year and they don't squeak. Edited July 29, 2009 by 92Pathmaker Link to comment Share on other sites More sharing options...
MY1PATH Posted July 29, 2009 Share Posted July 29, 2009 AH so its the logo side that strikes when you use larger diamer shocks. 92 do yours have the vekton bushings? A while back calmini swithced from derlin bushings to vekton bushings and I think that helped the squeak. I used energy suspension "formula 5" (its just a really thick bushing grease) when I installed and I have not had a peep ever. I has been 3 months so far. But honestly,I would use the superlift or roughcountry Unless the following applies to you; stubornly you MUST have the Beefiest UCA's you think its worth the price you don't mind making the cutout if you use bigger shocks you plan one re-coating them cause they don't prep the metal right for powdercoat. yes, I knew all that before hand, I'm a stubborn one. Lift range also seems to be closer to 2.5 than it is to 3" Link to comment Share on other sites More sharing options...
Kn0xville Posted July 29, 2009 Share Posted July 29, 2009 i personally like my rough country UCA's too . Link to comment Share on other sites More sharing options...
