Will a tire215/70 R15 fit the stock rim?
foxtrot044
Why put that on when a 31 will fit it? :scratchhead:
and yes.. I know some people will poo poo that.. but it works....
*poo poo*
The chromie has 235/75/15 factory, so heres some info-
235/75/15= 28.9x9.3/15
215/70/15= 26.9x8.5/15
You will be reducing width by apx 1", and diameter by apx 2", these would be small, but with your stock rims being 15x6, I don't see any reason why you couldn't run them...I wouldn't, but you could!
Just make sure they have the correct load rating!
*poo poo*
The chromie also came with 215s factory. I've seen in person. OSR, look in your glove box, I bet it lists the tire pressures for your 235s and 215s
Supose I should have listed some reasoning. Im turning in my car and want to keep my 31" mudder tires. I found a set for $50 that are the smaller size. Just wasnt sure if they would fit or not. Thanks.
actually I think your right, cause I think i remember reading the door sticker as having 215/70 stock
Nooooooooooooooooooo! :lol:
Are you doing the cash for clunkers?
