Titan Rims on a Pathfinder?
Endy
If I'm not mistaken, your pathfinder comes with 16 x 7 stock rim, right? Do you know what is the width of the new titan rim? 17" by??
And since its 17", I assume u gonna get a new set of tires to go with that...?
Theres a guy with a WD21 running the titan wheels, can't remember who it is off the top of my head though. Like alex said, he had to bore out the centre holes.
Hub on Titans is 78mm. On my 96 R50, the hub is about 110mm...so yeah some opening up would be needed. Plus, the 17" "Offroad" wheels have some crazy backspacing...like 7+ inches IIRC. I have a 2004 Titan and never had thought for a second the wheels would fit on my R50 even though the bolt pattern is the same.
From everything I have read the pathfinder hub is 100mm not 110mm.
