3 point Harness
OldSlowReliable
http://www.racinglab.com/sparco-harness-3-...-2-bolt-on.html
So im cleaning out my pathy today, and it comes to me, that i could probably mount that harness via-
- By removing that little latch that keeps the bottom portion of the seat latched in riding position and bolting down the top-most of the harness to that
- Removing the lower seat part and then bolting the two side belt things on the two spots where the seat is mounted
Anyone tried this? Im concerned that it may not be safe, because i have heard they should be bolted to the frame.
^^What he said.
If you mount them lower than your shoulders you'll compress your spine in a front end crash. And I wouldn't mount any point of the harness to the frame, especially in an older vehicle like the WD21. I've seen the rust around my body mounts and if they were to snap in a rollover I would want to be strapped to the shell of the body, not tied to the frame while the body is being ripped off.
