Winch Mount
Oh, there's ways, but there aren't any products out there other than the ARB and KMA bumpers that you can purchase. The other solutions will require a little creativity and ingenuity on your part.
You could implement a front receiver hitch, for a portable winch option. That would allow you to remove the winch when you're not using it, and protect it from theft and the elements. It would also allow you, if you were so inclined, to run winch cables to the rear of your vehicle and winch from either end. The downside of this is with the winch mounted, you do sacrifice quite a bit of approach and/or departure angle.
Another option is a "hidden winch mount". This is basically a winch mounting plate that you fabricate to mount a winch between your front frame rails, in front of the radiator/AC condenser. It's definitely possible to do, Marcel from BP did one a while ago, but he's not building anything currently. This would be a permanent mounting solution, that would allow you to retain your OEM bumper (with a little modification), and not sacrifice approach/departure angles. However, being a permanent mount, the winch would be exposed to the elements, and vulnerable to theft.
