starting rough
Nismojunky
well my pathy has been doing this for a wile i dont know whats going on with it. when its cold out it wont start up, it will turn over backfire then stall out, unless i hold the gas down at a 2000 rpm idle for a few mins untill everything is warm then runs fine, and will start fine once hes warm???? any ideas its driving me nuts...., and it backfires when im slowing down if that has anything to do with it.
when was the last time you did a tune up ?
the engine is missing...not running on all cylinders – running rough – hesitating etc. Usually something like the need for a tune up, spark plugs or spark plug wires are the culprit of misfiring.
sounds to me that your air to fuel is a little to rich
go to the back of your rig and smell the pipe , if there
is a raw fuel smell post if not do a compression test on
your rig to see if it fluxes
Edited by WiredWrong
