what is a WARN MANUAL HUB?
Guest pennypathfinder
Warn manual hubs replace the stock drive flanges on the front axles of your Pathfinder and make it so that you can manually lock or unlock the axles instead of having them be locked all the time, as they are in stock configuration. Older Pathfinders have automatic hubs instead of drive flanges that can be replaced with the Warn hubs to make them manually selectable for off-road use. The Warn hubs are lots stronger than the stock auto hubs.
  • 4 weeks later...
