ONE MORE THING
Guest pennypathfinder
OK so is the new set of rims really worth a barley bigger tire?? could you even get a bigger tire with the new rims than a 32???? and also i have 15 inch rims on now so can i still get the 16X7's??? Is american racing the my best bet on rims???
Which one.
16x7
0 offset
4 inch bs
bolt circle - 5x5 1/2 2WD & 4WD
OR
16x7
0 offset
4 inch bs
bolt circle 6x5 1/2 2WD & 4WD
15x8 is good for 31.5x10.5 up to 33x12.5
15x7 is a bit skinny fot those tyres
15x7 can run a 31.5x10.5 (I THINK!!!!)
go the 15x8 wheels & 31 or 32x10.5 tyres
1. thats your call
2. no, the largest tire that will fit with AC's 2" lift is a 32", regardless of the rim used
3. You can get 16x7's if you get new tires that fit 16" rims. but you have an early R50, right? So you don't need 16 inch rims to clear the brake caliper, 15" will be fine, cheaper, and tires for that size rim will also generally be cheaper.
4. american racing is a reputable brand with good products, but it you want black steel rims, just about any vendor will work.
5. If you look at your wheel, you wil see that you have 6 bolts, therefore a rim with a 5 bolt pattern will not fit. The correct pattern is 6x5.5
