cv axle or half shaft replacement
shortysmash
how hard or what all is involved in replacing a half shaft or cv axle on a 2001 pathy
Removing the strut assembly, moving the hub assembly out of the way, figuring out what needs replaced in your drivetrain. Is it clear what is broken/damaged?
yeah the cv boot is busted. There is grease all over the wheel well. I know that I could just put a repair boot on it but I dunno how long it has been without grease. Advance has a new cv axle for about 70 bucks. How much of a pain is it to get the axle out of the hub assembly
I'm sorry for that as i found out that the cv boot was busted i instantly came in and posted and as soon as i did i was reading on other pages and there it was. I appreciate the info though. I just finished up the fix and it def was as easy as it said in the thread. except for bolting the lower a arm back up
