dell1973 Posted September 28, 2008 Share Posted September 28, 2008 hey all wrote a post about my axle problem earlyer today i just went out and jacked up my 90 pathy to try and find that noise i was hearing . i spun the wheeel and the new axle shaft i put in yesterday spins in 2wd and the passengerside does not spin. do you think my auto hubs are bad.when in 4wd they both spin like they should. pass side unlocks when you spin it in reverse but driver side does not. driver side stays lock in 2wd and 4wd which also turns my front driveshaft.so what i'm say is in 2wd the driverside cv is locked and the other side is free. whats up with that? please help!!! Link to comment Share on other sites More sharing options...
Pathmaster95 Posted September 28, 2008 Share Posted September 28, 2008 Your auto-hub is stuck. You can try taking it apart and cleaning it with tranny fluid (do not use grease). It is probably just real dirty. A permanent fix is to replace both hubs with some manual hubs. Link to comment Share on other sites More sharing options...
dell1973 Posted September 28, 2008 Author Share Posted September 28, 2008 Your auto-hub is stuck. You can try taking it apart and cleaning it with tranny fluid (do not use grease). It is probably just real dirty. A permanent fix is to replace both hubs with some manual hubs. thankyou!!! Link to comment Share on other sites More sharing options...
