VillageIdiot Posted July 25, 2008 Share Posted July 25, 2008 I saw these on a pathfinder somewhere. Anyone seen them before? I like 'em except the three led looking lights above the headlights. I'm kind of leary because you can get a set for $300. I don't want to buy a big POS that's not going to be sealed and that's going to have problems with moisture or anything else. If it's just the shell, it may be worth it. Then I can fit in a set of HID's. http://lib.store.yahoo.net/lib/mytightride...rHeadlights.jpg Link to comment Share on other sites More sharing options...
nunya Posted July 25, 2008 Share Posted July 25, 2008 I normally don't see good after time with lights like that. As you fear they normally get 1 that fogs up or 1 of the headlight rings will burn out fast. Just my .02 Link to comment Share on other sites More sharing options...
VillageIdiot Posted July 28, 2008 Author Share Posted July 28, 2008 I normally don't see good after time with lights like that. As you fear they normally get 1 that fogs up or 1 of the headlight rings will burn out fast. Just my .02 Any other ideas? I might just get the HID kit and use it with the standard lights, but normally HID's are done with projectors. I'm not much of a light guy, so I'm unsure as to what to do. Link to comment Share on other sites More sharing options...
Extreme90path Posted July 29, 2008 Share Posted July 29, 2008 New caddies and maxis use non projector setups and they seem to work just as well as projector set ups if not better. Link to comment Share on other sites More sharing options...
VillageIdiot Posted July 30, 2008 Author Share Posted July 30, 2008 Cool. I might try that and get some lamix sheets to protect the lights. Link to comment Share on other sites More sharing options...
