Suspension and Air Filter
Daggym
Hey i own a 90' terrano 2.7td and been looking through the forums, just wanted to know from finding that f-100/bronco springs give bout 3 inch lift in the rear just wanted to know wat years of the f-100/bronco. Also wanted to know what size pod filter fits on the original air intake pipe?
JEEP GRAND CHEROKEE or JGC coils work too. try the search function with someting like "jgc coil"
'78-86 or so on the front Ford coils. Beware though, the only reason they give lift is because they're a much higher spring rate than stock. They end up being shorter than stock and can fall out if you flex the rear far enough.
