moospis Posted June 7, 2008 Share Posted June 7, 2008 Hi all- I recently had a problem with trailer harness wiring for my '91 pathy. Well, I found a harness from etrailers that I hooked up and all of my boat trailer lights work! Yaaahhh... then I went to get into my truck last night and now I have running lights when I am in park with all of the lights off. I know I have a good ground but this has me confused. Can anyone help? Link to comment Share on other sites More sharing options...
88pathoffroad Posted June 7, 2008 Share Posted June 7, 2008 Might be the headlight switch, but if you recently did the trailer wiring, I'd check that first. Can you unplug the wiring you installed without a hassle or is it spliced in? Link to comment Share on other sites More sharing options...
moospis Posted June 9, 2008 Author Share Posted June 9, 2008 Might be the headlight switch, but if you recently did the trailer wiring, I'd check that first. Can you unplug the wiring you installed without a hassle or is it spliced in? To 88path- I bought a plug-in harness which was truck specific that I plugged into my taillights on my truck. It had 5 wires before that I cut off and taped off to prevent grounding. Would one of those wires make that happen if they grounded? I know my stereo quit working and I re-wired that and that works fine so why do I all of a sudden have running lights with no lights on? I guess I could unplug the harness until I need it..... Link to comment Share on other sites More sharing options...
