moospis
Everything posted by moospis
  1. To 88path- I bought a plug-in harness which was truck specific that I plugged into my taillights on my truck. It had 5 wires before that I cut off and taped off to prevent grounding. Would one of those wires make that happen if they grounded? I know my stereo quit working and I re-wired that and that works fine so why do I all of a sudden have running lights with no lights on? I guess I could unplug the harness until I need it.....
  2. Hi all- I recently had a problem with trailer harness wiring for my '91 pathy. Well, I found a harness from etrailers that I hooked up and all of my boat trailer lights work! Yaaahhh... then I went to get into my truck last night and now I have running lights when I am in park with all of the lights off. I know I have a good ground but this has me confused. Can anyone help?
  3. Thanks to all I hooked up my harness I bought from etrailers.com and what do you know! All the lights on my boat trailer work! This thing works great. All I did was plug and test. Thanks to all who posted and dont forget etrailers. They are great!
  4. Hi all- to Ghostpath, kiwipete, dagwoodzz and all who replied to my post. I believe I found the solution at etrailers.com. I went to hitch dealers and found the wire harness specific to my pathfinder. You guys had me on the right path with the t-connector. I just had to find the right one. Hopefully, I should be ready to go by this weekend since the part is coming from missouri to minnesota. Thanks to you all! pc_VWH_118353.htm
  5. But there is still one more wire- my 91 pathy has 2 on the driver side and 3 on the pass side slick we are still short a wire so something has to get fused with another since you have a 4 flat plug right?
  6. ok dag but what about the left side with the other 2 wires? Is one the ground and the other the running or hazards? Im still confused
  7. tx dagzz and all- ok so how does that wesbar connector work? does it hook into the rear panel?
  8. im sure im grounded on trailer but truck im not sure about will have to check it out
  9. hi all- i have a 91 pathy that has 5 wires from the rear wiring harness 2 from the left blinker and 3 from the right side. i have a 4 wire flat plug on my boat trailer. i have tried every combination to get these wires correct and all i do is blow fuses. does anyone know the correct wiring for this vehicle?
