2003 pathfinder trouble code
pkmcd99
First step in all evap leak codes - remove and retighten the gas cap, clear the code and see if it comes back. if you were to go to a shop this is exactly what your first hour of diag time (at full shop rate) will be spent doing.
so ive reset the ecu, and re-tightened gascap. light comes back on after about 20 miles. same code. P1456 now what?
