Body Lift Bolt Question
statikuz
Alrighty, I just installed, for the most part, my new body lift... but I have a question about the bolts I used. I got 12 in the box, and I only need ten... I got six silver normal bolts, four silver metric bolts, and two thicker black bolts. I used all of the silver bolts, the metric ones went in the very back and between the doors, and the normal silver bolts went in all the other holes. Didn't so much use the black ones, because the other ten seemed to fit alright in the places I chose. Did anyone else have this problem? Which bolts are which? Am I fine not using the black ones? Everything seems to thread in and whatnot okay, but I dunno. Thanks!
I dont remember what goes to what, but all I really remember about it is that I had a crap load of bolts left over ... the body of my rig hasn't fallen off yet so I think it would be safe to assume that it is going to be just fine ...
one each side you should be using 4 silver bolts with their nuts and washers and i believe a thick black bolt for the very rear mount. The very rear mounts just screws into the body. I'll have to go down to my garage and double check for you...... oh wait i have a picture of it in my cardomain site of the leftover crap. let me pull it up real quick.
This is all that you should have left from your body lift:
Matterhorn remember that you have an 87 pathy and statikuz has a 93--two different body styles.
edit: hey statikuz, did you have those big washers like I did under the second body mount starting from the front of the Pathfinder? Mine did and I took those out since I didn't think I need them, as you can see.
Yep, the two black bolts went in the rear mounts just fine... I guess they sent me two extra of the silver metric bolts. Whatever. =) Oh yeah, and Cuong... I dunno about the big washers, mine just had the rubber bushing thing between the frame mount and the nut on the end...?
