russkigreg Posted February 20, 2008 Share Posted February 20, 2008 Hey all, Have a problem with my Terrano's automatic transmission - it doesn't want to shift past third gear. Engaging or disengaging overdrive has no effect either. It is the stock four speed with overdrive box. Took it to an automatic transmission specialist and they said there's nothing wrong with the box itself - more likely to be the ECU/ECM in the vehicle. Any ideas? Also, where is the ECU/ECM in a 92, there's a silver box under the driver's seat...? Ta, Russ Link to comment Share on other sites More sharing options...
TerranoNZ Posted February 21, 2008 Share Posted February 21, 2008 1 question 2 door or 4 door? The 2 door auto ECU is mounted behind the plastic panels in line with the rear seat on the right hand side. Where the rear door would be on a 4 door (Don't know where it is in a 4 door) The box under YOUR drivers seat is the ECU for the engine. (IIRC Russki's have the steering wheel on the RIGHT side of the Truck) Hope someone else might be able to help you more Link to comment Share on other sites More sharing options...
packie88 Posted February 21, 2008 Share Posted February 21, 2008 mine wouldnt shift outta second about a year ago, and when i took it in it turned out to be the whole transmission had to be replaced. so you could need a new tranny Link to comment Share on other sites More sharing options...
boothill2008 Posted February 21, 2008 Share Posted February 21, 2008 Hey all, Have a problem with my Terrano's automatic transmission - it doesn't want to shift past third gear. Engaging or disengaging overdrive has no effect either. It is the stock four speed with overdrive box. Took it to an automatic transmission specialist and they said there's nothing wrong with the box itself - more likely to be the ECU/ECM in the vehicle. Any ideas? Also, where is the ECU/ECM in a 92, there's a silver box under the driver's seat...? Ta, Russ Hi Russ, I have had a 1993 and a currently own a 1992 Pathy SE, both had to have trannys replaced unfortunately. So I have to agree with Packie88, you may need a new trans. Sorry, Boot Link to comment Share on other sites More sharing options...
