Xmas Posted January 29, 2008 Share Posted January 29, 2008 Recently the fluid that squarts water to my windshield is not working. However when I need fluid for the back window it does work. I am thinking that maybe the switch that you engage the wiper fluid might be bad? I mean due to the fact that I think its only one motor that runs pressure to squart the fluid to either front or back windows. ANyone else think differ?? Link to comment Share on other sites More sharing options...
kiwipete Posted January 29, 2008 Share Posted January 29, 2008 On the New Zealand models thre are two squirter motors. One for the front and one for the rear. Here you can see the two pumps, one on the top and one on the bottom. You may have a burnt out pump, unplug the wires and check for voltage when you switch them on. Link to comment Share on other sites More sharing options...
Cuong Nguyen Posted January 29, 2008 Share Posted January 29, 2008 Year there are two squirters. A long time ago, I found the reason why the rear one didnt work was becuase it was stuffed full of sugar ants. Could be that the pump is out. Link to comment Share on other sites More sharing options...
Xmas Posted January 30, 2008 Author Share Posted January 30, 2008 Year there are two squirters. A long time ago, I found the reason why the rear one didnt work was becuase it was stuffed full of sugar ants. Could be that the pump is out. Well for a while it was working flawless and then it started to act up and work sometimes. Now its like NADA! No workey. I wonder how much one of these cost. Thanks u2 Link to comment Share on other sites More sharing options...
