TEST PIPE ?
drifter
94 4x4 path 5 spd , 2.5 exhaust 40 series flo-master/Thorley headers. Was thinking of swapping out my cat for a test pipe, my question is will the test pipe upset engine light, back pressure etc... and will i gain any hp. or gas mileage ??
there will not be any difference in power if you remove the cat. i would up grade to all 2.5 inch with a hi-flow, or if you are in an area with no emissions then just ignore the cat.
I was talking to a guy that owns a exhaust shop and he said the hi-flo cats where no different than a regular cat ?? It was just a marketing sceme.
That would be no.
There is a demonstrable difference, both on the dyno and on a flow-bench.
See this: http://images.magnaflow.com/05news/magazin...f/catalytic.pdf
I would avoid having work done at this man's shop.
Edited by GhostPath
the reason they are 'hi-flow' is because they contain so much less catalyst than OE style converters do. If you cut a 'hi-flow' cat open you will see 2 blocks maybe 2 inches thick. if you cut an OE converter open you will see 2 way thicker blocks that fill the entire case up.
