Which Rims interchange ?
nessy357
I'm looking to buy a set of rims to mount my snowies on.
Can you tell me which rims (Toyota etc) will interchange with my 97 Pathie pls ?
thanks Bob.
I think you can use anything, as long as they have a 6x5.5 bolt pattern and the centre bore where the hub goes through is over 100mm
some chevy, and most toyota rims will fit, as per the specs Nissan3 specified.
Also, any Nissan mid sized truck rim will fit, from 87-2004, as they all shared the same bolt pattern.
