chris8042002 Posted November 23, 2007 Share Posted November 23, 2007 Newbie to this forum, but have been lurking for a while. Here goes: Almost every morning when I start my Pathfinder, I get a check engine light almost immediately, and some rough idling......take off down the road, and experience surging, hesitation, stumbling, near stalling at stop lights......after 5 minutes or so, the light goes out, the rig runs perfectly, like a top, and will do so for the rest of the day. Pulled codes today, got a 33: Exhaust Gas Sensor My confusion: After doing some research on this forum and others, it seems like the O2 sensor doesn't come into play when the vehicle is first started and cold. Should I just trust the code reading and replace the O2 sensor, or try something else (cheaper!) first? Could someone please explain the function of the O2 sensor in a cold engine? Thanks in advance, and I'll be sure to provide updates on this issue when I tackle it. Chris Link to comment Share on other sites More sharing options...
Simon Posted November 23, 2007 Share Posted November 23, 2007 Mine did that when my O2 sensor was bad......though, my CEL stayed on constantly. Link to comment Share on other sites More sharing options...
GhostPath Posted November 23, 2007 Share Posted November 23, 2007 Replace the O2 sensors. IIRC, that's a three or four wire type, so it's heated. That means that the computer starts looking at it after 30-90 seconds. If the heater isn't working because of age killing it, you will get that code. Link to comment Share on other sites More sharing options...
