bomberman Posted November 14, 2007 Share Posted November 14, 2007 so i thought about doing a swap from auto to standard but i dont think my trans will hold out the long. also i have decided to stay with the auto. so my questions are my auto will sometimes not shift out of first so i talked to a place about getting it rebuilt they said it may be electrical is that possible also my trans gets warm i can smell it when i get out of the truck i dont have a tranny cooler but it still should not get that warm so i found a used trans for 650 bucks or they said that worst case it could cost 2000 -2600 so any help would be great Link to comment Share on other sites More sharing options...
Simon Posted November 14, 2007 Share Posted November 14, 2007 (edited) It WILL get that hot if the stock cooler (inside the rad) is clogged. That is a very common happening with WD21 Pathfinders, and the #1 killer of the autos. That's a tell-tale sign that your tranny is overheating. Get that stock cooler bypassed, and put in an aftermarket cooler. That alone may be enough to give you some more life out of it, and help your shifting issue. Edited November 14, 2007 by Simon Link to comment Share on other sites More sharing options...
bomberman Posted November 14, 2007 Author Share Posted November 14, 2007 thanks Link to comment Share on other sites More sharing options...
Hud Posted November 15, 2007 Share Posted November 15, 2007 Ditto... to what Simon said... I've lived this nightmare twice with auto trannys. and have learned quite a bit about it... Definately get a external trans cooler... if not before during the swap or the rebuild... That quote is a safe bet... both of my rebuilds costed around 2000 grand...each on that is... Link to comment Share on other sites More sharing options...
