JB3829 Posted November 2, 2007 Share Posted November 2, 2007 I need to change a plugged injector..any suggestions or how to's? thanks, JB Link to comment Share on other sites More sharing options...
tmorgan4 Posted November 2, 2007 Share Posted November 2, 2007 If you need any injectors I've got 6 good ones! The plenum isn't the easiest to take off while it's in the vehicle. Link to comment Share on other sites More sharing options...
nissandoms47 Posted November 2, 2007 Share Posted November 2, 2007 Which bank is it on? Link to comment Share on other sites More sharing options...
JB3829 Posted November 4, 2007 Author Share Posted November 4, 2007 It's the #1 cylinder(as far as the tcode is concerned) and its actually for my 2000 quest (same engine as my '97 pathy) I poured about a can of seafoam down the intake, but it keep coming back Link to comment Share on other sites More sharing options...
88pathoffroad Posted November 4, 2007 Share Posted November 4, 2007 Um, pouring SeaFoam into the intake will not touch the injectors. You'd have to put it in the gas tank for that to work. Link to comment Share on other sites More sharing options...
JB3829 Posted November 4, 2007 Author Share Posted November 4, 2007 Um, pouring SeaFoam into the intake will not touch the injectors. You'd have to put it in the gas tank for that to work. Thanks for enlightening me 88....still confused though. This goes back to when I sprayed throttle body cleaner into the tb and a lot of it didn't pour out. Then I poured seafoam into a vacuum line. That is when I got the cylinder 1 misfire and knock sensor trouble codes. The engine was idling really rough for awhile but seems to have smoothed out. I figured it was a clogged injector......the plugs are all clean. The rough idle started right after I poured all that cleaner in there. what else could it be? thanks again Link to comment Share on other sites More sharing options...
