headlight wiring harness
chappy
I'm hooking up some fogs and wasn't sure where the best place to tap into the high beams was. Pre harness right after the head lamp or further away from the head light? It looks like the used hockey tape to insulate the wires before they enter the harness :shrug: Thanks guys.
Hi, My pathy used to have fog lights on it. Where they had been spliced into the original loom managed to short out and cause a fire under the hood.
I ended up Buying a Piranha Off Road super loom which has a trigger wire for driving lights. If you could find a Male H4 connector (the same as the back of a headlight globe) I could give you the measurements to make your own. It plugs into the orginal headlight socket and wires to the battery.
This loom made my headlights alot brighter than the original.
P.S. If you find somewhere the sells the male H4 connectors can you let me know. Thanks.
