varn Posted September 17, 2007 Share Posted September 17, 2007 2002 Pathfinder 4WD So, I've found some info that my "front tubes" as Nissan calls them are leaking on my exhaust system - most notable when cold. Nissan Bullet NTBO4-092 calls them "front tube", anyway. The look like Catalytic Converts to me. The Catalytic Converter is covered under warranty up to 80K miles or 8 years. Checked the owners manual, and there isn't a catalytic converter in the manual. Are these really Catalytic Converters? (The service bulletin says "The front tubes may look like catalysts, but they are (by design) NOT catalysts." Confused. Link to comment Share on other sites More sharing options...
88pathoffroad Posted September 17, 2007 Share Posted September 17, 2007 They are resonator tubes, not cats. I have yet to see Nissan cover any exhaust problems under warranty or for free on any vehicle older than one or two years. Link to comment Share on other sites More sharing options...
varn Posted September 26, 2007 Author Share Posted September 26, 2007 They are resonator tubes, not cats. I have yet to see Nissan cover any exhaust problems under warranty or for free on any vehicle older than one or two years. Thanks for the response. So, where's the catalytic converter? It's not mentioned in the diagram they provide in the manual I have. Link to comment Share on other sites More sharing options...
88pathoffroad Posted September 27, 2007 Share Posted September 27, 2007 I believe you have two pre-cats at the base of the exhaust manifolds, then the resonator tubes, then the cat, then you have a resonator and then a muffler with a tailpipe. Crazy, huh? Get yourself a factory service manual, there are several places you can download one for free, like phatG20.net. Link to comment Share on other sites More sharing options...
navygz19 Posted September 27, 2007 Share Posted September 27, 2007 I would JB weld that thing and call it a day. Contacting the dealership will be more of an effort than it's worth. I had both front tubes replaced because they were both rotted out and leaking, but I'd just bought the truck from Carmax and they were replaced under warranty. Like I said, JB Weld's your friend Link to comment Share on other sites More sharing options...
Destro Posted September 27, 2007 Share Posted September 27, 2007 Nissan actually has a patch kit for this problem. It is basically JB weld and a metal crimp to go on the ends to seal it up. Should cost you about $300 parts and labor for a Nissan dealer to patch them for you. Link to comment Share on other sites More sharing options...
