Quest E-fan
95NPATHYSTYLE
It seems that the pic attachment function of this board has ceased to function. I'll try putting in a trouble ticket if I can get Jim's attention.
You have one wire for low speed and one wire for high speed. What do you mean by "which relay should I use?" What kind, or how to wire one up, or what? An e-fan thermostat kit will come with a relay and instructions...
I don't have a kit just an adj. themro. What amp relay do I need? And by testing the fan i cant see a speed diff. I'm guessing that the hot w/ the ground is norm. speed & the seperate hot is hi spee? Is that correct?
Edited by 95NPATHYSTYLE
