H233b Pinion Bearing Numbers
SteeevO
I'm looking for bearing numbers for a 92+ H233B Pinion. not factory part numbers but the numbers actually printed on the bearing itself.
if nayone could post them up here. it would be a great help.
Thanks,
-Steven
Thanks,
-Steven
I don't have the part numbers with me right now, however the cheapest place I found them at was rock auto(online parts retailer). The local parts houses wanted 50 bucks for the small one and 90 bucks for the large one. They were the exact bearing that were in there stock
I got both at rock auto for under 60 bucks.
I will look and see if I still have the old bearings, and see if i can get the part numbers off of it when I get home.
Mark
Mark
That would be great! i just ordered some bearing from the dealer (rip off!) so as soon as you get the bearing numbers to me i can cancle the order at the dealer. Thanks!
-Steven
-Steven
well it turns out the old bearings and boxes fell victim to a garage cleaning. They are gone. I did find my invoice from rock auto, maybe it will help.
BCA/NATIONAL 32308C Differential Pinion Bearing $ 32.79 $ 0.00 1 $ 32.79
BCA/NATIONAL 710245 Differential Pinion Seal $ 12.75 $ 0.00 1 $ 12.75
BCA/NATIONAL 32306C Differential Pinion Bearing $ 25.79 $ 0.00 1 $ 25.79
sorry it took so long to reply. I Had a bunch of crap hit the fan and was not able to get back to the board.
However I remember matching the old bearing to the new one and the numbers and brand were identical, Also I have a bunch of the spacers(shims) left over from my job. I measured mine and ordered one size up and down plus the original size for each of the 3 spacers. (spent 100 bucks in shims from the Nissan dealer) Of course the dealer does not accept returns on special orders so I am stuck with them. May be of some use to you.
Mark
