89pathfinder Posted June 28, 2007 Share Posted June 28, 2007 Alright, well now that its almost time to lift my pathfinder, i have contemplating a few different ideas. I was originally going to go with a 3 inch body lift and 3 inch suspension. So heres my first question, to those who have installed or helped install a body lift how hard was it to do? What problems could i run into? Now for my next question, was is the maximum possible lift that i can get out of the front independant suspesion? Link to comment Share on other sites More sharing options...
88pathoffroad Posted June 29, 2007 Share Posted June 29, 2007 It's not that bad if you take your time, and the max you can go is a 4" Trailmaster suspension lift, new aftermarket UCA's cranked up 3" or so, and the 3" body lift for a theoretical total of 10 inches. Link to comment Share on other sites More sharing options...
89pathfinder Posted June 29, 2007 Author Share Posted June 29, 2007 Well what exactly does the trailmaster lift do to lift up the front. I know it drops the torsion bars but how does that lift the front end up without cranking the t bars? In the picture they have on the website the lower a arms are horizontal just like stock, not angled downward like after cranking the the torsion bars. Link to comment Share on other sites More sharing options...
cohen Posted July 8, 2007 Share Posted July 8, 2007 It has a "drop down bracket" that kinda looks like a rectangular piece of steel that lowers the control arms, torsion bars, etc. Check out the picture of all the parts. Link to comment Share on other sites More sharing options...
88pathoffroad Posted July 9, 2007 Share Posted July 9, 2007 It drops the mounts for the front diff, the torsion bars on both ends(front and rear) and includes a knuckle adapter that bolts to the stock steering. It is a true 4" lift kit, unlike just UCA's and t-bar cranking. Link to comment Share on other sites More sharing options...
cohen Posted July 9, 2007 Share Posted July 9, 2007 how hard is that to do... Link to comment Share on other sites More sharing options...
Slick Posted July 9, 2007 Share Posted July 9, 2007 if you want it bad enough, and can't afford to have it installed, you will just stop asking how hard it is and install it. it is not impossible, and not "near" impossible if you have 50% of your brain matter left and a good set of tools, a couple good friends and you're not illegitimate. air tools are a HUGE bonus. it is not a 2 hour install, but it can be done in a weekend. here is what a 4" TM SL looks like (excuse mud and other yuck down there.. but you get the idea) Link to comment Share on other sites More sharing options...
