89_trailboss Posted June 26, 2007 Share Posted June 26, 2007 wasnt going to post this up till I was much closer to being finished. or atleast till it resemabled a truck but I ran into some unexpected things latley so this projects off for a month or so. So I figured I will post up what I have started. couple months back I sold my 89 pathfinder. I loved that truck but it was rotting way to fast. plus after only 8 months, my trans was about to kick the bucket(weird cause my other trans only lasted me 8 months till the input shaft snaped). anyways, heres the plan; my new truck is pretty much going to be a truggy. the front half of the frame is from an 89 pathfinder. the rear half has been tubed(still two more main trubes to be added). going on the frame is the cab from my 87 king cab HB. full EXO. allpro style bed. Drive train is going to start off as a VG30i rebuilt top end. P&P heads and intake manifold with an M90 sitting ontop. behind that is a 5 speed with TX10 then a 720 case. Axles are out of a 73 3/4 ton J series. Rear is a FF D60. 5.38's, welded, Disk brake swap. Front is a HD D44, 5.38's ARB or OX , superior shafts, Warn hubs, Hydro asst. rear is going to be a double triagulated 4 link with 18" Fox air shocks. front is going to be a 3link with 16" coilovers(more then likely FOA's). Going to be running 39.5x13.5 Iroks on 16" rims. nuff blah blah blah. heres a coulple quick pics: Frame, ~31" under the frame rails. rear links. 2x.250" DOM. 49" long, eye to eye. D60 trussed with 1.6x.125 DOM. 3/8" plate ontop rear link mounts. 1/4" driveshaft to mount 720 case behind TX10 720 case behind TX10. Long and ugly but should work great. with a 112" wheelbase my rear driveshaft is still ~30" long. plus cause the outputs are below the inputs on the 720 case, it should help with my drive shaft angles. Link to comment Share on other sites More sharing options...
bryfry Posted June 26, 2007 Share Posted June 26, 2007 Interesting welding job, kid. I'm sure your neighbors are thrilled. Link to comment Share on other sites More sharing options...
88pathoffroad Posted June 29, 2007 Share Posted June 29, 2007 Wow, what a project! I can't wait to see what it'll look like finished. Link to comment Share on other sites More sharing options...
