94 Pathy and nothing out there
Guest pixel
YES YOU DO HAVE TO CUT THE TIE RODS DOWN! and you also have to cut the adjuster sleeve... the lift can be done with just jackstands and basic tools, but drilling here and there is going to be very difficult, and having a friend to help you with front diff placement and rear axel relocation is a good idea ... in other words, the more room you have to work under there the better ... the jack stands should be pretty tall ... I would rate the lift about an 8.5 ... dont get me wrong ... it is hard to do ... especially if you have limited knowledge of the Pathfinder IFS ... do yourself a favor and research EVERYTHING FIRST ... you can ask me questions until you are blue in the face ... I dont mind ...
