csutke Posted May 24, 2007 Share Posted May 24, 2007 Ive looked at all the post on this topic and i still cant fin dthe answer to my question. I have a 98 with the AT, does this have an intregrated tranny cooler or is it extrenal. If is it in the radiator are the lines for it at the bottom and are they the ones leading to the tranny pan. Im looking at getting an aftermarket cooler and need to know if i can use these line if they are tranny cooler lines? Thanks, Isaac Link to comment Share on other sites More sharing options...
SaKaNa Posted May 24, 2007 Share Posted May 24, 2007 Look at the front, passenger side in front of the AC condenser, if you have an auxillary external one its a little black cooler over towards the bottom.. Otherwise its in the radiator... I replaced my itty bitty auxillary one with a Hayden 403 cooler, its more than twice the size of the last one, I just had my mechanic stick it in when he was doing my timing belt... Thats my Hayden, it was $50 or so, I'm not sure what installation cost. Link to comment Share on other sites More sharing options...
lewisnc100 Posted May 24, 2007 Share Posted May 24, 2007 This link might help with the ATF flow. If you don't have the external air cooler then the line will just return from the radiator cooler back to the transmission. http://groups.msn.com/LewisPictures/shoebo...o&PhotoID=3 Link to comment Share on other sites More sharing options...
