Audio Question
I'm not sure exactly what your problem is, but if you want to bypass the stock amps regardless...
...search first. =)
"The Nissan Pathfinder came stock from the factory with 2 amps located in the rear of the vehicle on the right side behind a panel. These amps supply power to the speakers (ie: one amp for fronts, one amp for backs)."
