MaSteRmAcK Posted May 18, 2004 Share Posted May 18, 2004 Does anyone know if I can put on a set of 2004 Nissan Titan 17" rims on my 1989 Pathfinder? Will I have a problem with the fron hub being to big for this rim? Can I get a spacer? Any info would be greatly apperciated. Thanks! Link to comment Share on other sites More sharing options...
88pathoffroad Posted May 18, 2004 Share Posted May 18, 2004 You'd have to put some mighty expensive almost low-profile tires on those 17's to get 'em to fit your Pathfinder. Check the backspacing and see if it's anywhere near 4.5" or so...they may fit, but I dunno. Link to comment Share on other sites More sharing options...
squam1 Posted May 18, 2004 Share Posted May 18, 2004 manual hubs may or may not be an issue... the other question is do the wheels have the 33" tires from the factory, in which case, that may prove to be an issue as well... Link to comment Share on other sites More sharing options...
big_johnson Posted May 19, 2004 Share Posted May 19, 2004 here is a direct quote from someone selling some Titan rims a while back: "Will not fit a normal Nissan" So I don't think they would fit the pathy Link to comment Share on other sites More sharing options...
squam1 Posted May 19, 2004 Share Posted May 19, 2004 I don't know what the back spacing and all that may be, but I have 17" rims on my '02... I suspect that there is enough difference between the 89 pathy and 04 Titan that there would be some issues... that being said, if the bolt pattern is EXACTLY the same and the backspacing is roughly the same, I'd say the only limiting factor is the tire size that you intend to use. And let me tell you, if I may, that there aren't a helluva lot of 17" tires worth their salt out there. Biggest issue is the availability of sizes!!!! I've debated the idea over and over about using 16" stock Nissan wheels for my mud tires when I go to get them, but I just can't justify the overall cost when you can get such cool aftermarket wheels cheaper and with greater availability... 16" wheels would be your best bet in my opinion. Unless you are getting the wheels for free or like rediculously cheap, I'd say skip it and get some cool steel wheels real cheap... Link to comment Share on other sites More sharing options...
squam1 Posted May 19, 2004 Share Posted May 19, 2004 oh, and after you get the steel wheels real cheap... go get something else really cool with all the dough you saved... Link to comment Share on other sites More sharing options...
Little Mule Posted May 21, 2004 Share Posted May 21, 2004 Adding to squam1's statement: And take some pics and let us see when you are done. I wanna see. Link to comment Share on other sites More sharing options...
