87mudfinder Posted May 18, 2004 Share Posted May 18, 2004 I have acess to a machine shop thinking of doing this just for the bling bling of it all? Anyone else done this? I have done this to past motorbikes so thinking to do the Pathfinder for the ease of the brakes. :eek: drilled rotors drilled rotors oh so blang blang Link to comment Share on other sites More sharing options...
88pathoffroad Posted May 19, 2004 Share Posted May 19, 2004 Well...dunno about drilling a set of stock rotors. You could try it and see. *shrug* Link to comment Share on other sites More sharing options...
revgolem Posted May 19, 2004 Share Posted May 19, 2004 Honestly that really wouldn't be a good idea. The rotors you have now are designed to work as is, and you would be severly weakining then and they would be more prone to warping. You will also reduce the amount of material making contact and reduce the friction. The material and the surface of the pre-drilled rotors are designed with that in mind. And if you do go and get the pre-drilled rotors definatly get the pads they recommend as well, it's all about getting just the right amount of friction. Link to comment Share on other sites More sharing options...
JeepRescueService14 Posted May 20, 2004 Share Posted May 20, 2004 Drilled rotors crack.. thats it.. theyre made of cast iron and dont like that abuse especially with the brake pad passing over them over and over.. btw.. you want a 4x or an indy car.. as far as "bling"? how bout a lift kit Link to comment Share on other sites More sharing options...
87mudfinder Posted May 21, 2004 Author Share Posted May 21, 2004 MY NEW TIRES HEHEHEHHE Just got these today delivered for 600 bones canada bucks... I am seeking 88offroads advise as to the cheapest method of getting me a lift asap. Link to comment Share on other sites More sharing options...
87mudfinder Posted May 21, 2004 Author Share Posted May 21, 2004 So thus stock rotors suck being that they (Nissan) makes an aftermarket available that is higher end? If so please point me a link please. :allclean: Link to comment Share on other sites More sharing options...
JeepRescueService14 Posted May 22, 2004 Share Posted May 22, 2004 put a disk brake rear end on... STOPPING POWER!! Link to comment Share on other sites More sharing options...
somethingcool Posted May 22, 2004 Share Posted May 22, 2004 Get some slotted rotors like these: http://store.yahoo.com/streetbeatcustoms/r...01-rot168420290 You get the extra gas disipation without having to worry about cracking... Link to comment Share on other sites More sharing options...
squam1 Posted May 22, 2004 Share Posted May 22, 2004 I'll let you know what my results are after installing cross drilled rotors on my 02... got them from precision brakes - SP Performance cross drilled rotors. Gonna try and get them installed memorial day weekend - along with the 2" A/C lift... (and diff guard and man hubs - if they fit) Link to comment Share on other sites More sharing options...
87mudfinder Posted May 22, 2004 Author Share Posted May 22, 2004 Well i am totally screwed because of 88offroad he has me hooked up on this baddd. I just installed the 31 10.5 15 bfgoodrich's on the 87 and wow mang they look hot! I am going for a body lift of prob 4 inch this week (doing myself) then bumpers buidling a light bar on top like the had to find stock ones and a roofrack stat! Welder in full run now... Pictures of the conquest coming soon befores and afters... Link to comment Share on other sites More sharing options...
